| Subject: LAV-III Armoured Wheel Hub - CDN edition Tue Dec 18, 2018 10:35 am | |
| On a Side note, I also quickly made up an armoured hub cover for Dean's LAV-III water tank... What is mounted on Canadian LAV-III's and the quick and dirty model... I wasn't too concerned with accuracy, since the LAV isn't that detailed, but at least somewhat close. |
| Subject: Re: LAV-III Armoured Wheel Hub - CDN edition Tue Dec 18, 2018 3:34 pm | |
| Cool! Send it over and I'll print some off... _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: LAV-III Armoured Wheel Hub - CDN edition Fri Dec 21, 2018 8:33 am | |
| Did you print with it at all yet? Found out my print nozzle died at the end of that proto-print of this (Which fit perfect in the wheel BTW). |
| Subject: Re: LAV-III Armoured Wheel Hub - CDN edition Fri Dec 21, 2018 8:50 am | |
| This weekend... _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: LAV-III Armoured Wheel Hub - CDN edition Thu Dec 27, 2018 6:57 pm | |
| So finally also disassembled the LAV completely... The Crappy Drive system... I need to measure the voltages to run the various aspects of the unit. Motor, Steering, Turret, Waterpump... |
| Subject: Re: LAV-III Armoured Wheel Hub - CDN edition | |
