Tamiya IR emitter Icon_minitimeby dgsselkirk Yesterday at 4:42 pm
» Matomart Sale again
Tamiya IR emitter Icon_minitimeby MikeC Sun May 05, 2024 10:59 pm
» TongDe New Tank
Tamiya IR emitter Icon_minitimeby Abteilung 506 Sun May 05, 2024 5:48 pm
Tamiya IR emitter Icon_minitimeby Robert B. Marks Sun May 05, 2024 1:08 pm
» Martin's PZ III combat god?
Tamiya IR emitter Icon_minitimeby Abteilung 506 Sun May 05, 2024 9:39 am
Tamiya IR emitter Icon_minitimeby dgsselkirk Sun May 05, 2024 1:52 am
Tamiya IR emitter Icon_minitimeby dgsselkirk Sun Apr 28, 2024 5:20 pm
» Panther 1 to 1
Tamiya IR emitter Icon_minitimeby Jarlath Sun Apr 28, 2024 3:47 pm
Tamiya IR emitter Icon_minitimeby MikeC Sun Apr 28, 2024 12:51 pm
Tamiya IR emitter I_vote_lcapTamiya IR emitter I_voting_barTamiya IR emitter I_vote_rcap
 Tamiya IR emitter
Tamiya IR emitter Empty
PostSubject: Tamiya IR emitter   Tamiya IR emitter Icon_minitimeSun Oct 11, 2020 12:13 am
So one of the issue with Tamiya IR emitter is that they only shipped with a TBU, Tamiya provides a unique mount for each of its tank because it is barrel mounted and is different from tank to tank. The problem is that there isn't enough of these to go around as most of us don't have one set of TBU/IR emitter for each of our tanks (Of course Tamiya expect that but it is simply too stupid). Moreover ,these mounts are too tight for the barrel and they usually ended up scratching the nicely finish metal barrel.
So I have been trying different solutions but then I discover that the standard 2mm JST plug with some trimming will actually fit the Tamiya connectors (which I believe are molex) as they have the same 2mm pin spacing.
To make a long story a little shorter, I have now starting to fit DIY IR emitter on my Tamiya tanks without using the butt ugly barrel clips, and during my testing of these new IR emitter, I was reminded again about this little Tamiya quarks. Unless a TBU is plugged into the base, the IR emitter will not function. I guess this makes sense if you think about it, as you cannot have a tank that does not have a TBU (i.e. Take hits) starting hitting other tanks on the field.
None of the other after market boards actually has this "feature".
PostSubject: Re: Tamiya IR emitter   Tamiya IR emitter Icon_minitimeSun Oct 11, 2020 12:50 pm
Did you fix the issue can you send pics ...Thanks Mike
Tamiya IR emitter Soviet10
PostSubject: Re: Tamiya IR emitter   Tamiya IR emitter Icon_minitimeSun Oct 11, 2020 7:41 pm
So take these 2 mm JST-PH plugs which is very common with most RC toys when you open them up, just shave off the two notch and also the ridge down the middle and they will pop right into the Tamiya 2 pin connectors on the MFU.
Tamiya IR emitter Dsc_1710
Tamiya IR emitter
» Barrel Mounted IR Emitter Attachment System???
» Heng Long King Tiger IR emitter problem
» New emitter type
» Emitter Bulb Replacement?
» infrared emitter frequency
