Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeby Hammertime999999999 Today at 5:26 am
Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeby Hammertime999999999 Today at 5:08 am
Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeby dgsselkirk Thu Apr 25, 2024 7:26 pm
Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Team Hippo (HL Stug III) keeps throwing tracks in grass I_vote_lcapTeam Hippo (HL Stug III) keeps throwing tracks in grass I_voting_barTeam Hippo (HL Stug III) keeps throwing tracks in grass I_vote_rcap
Team Hippo (HL Stug III) keeps throwing tracks in grass Empty
PostSubject: Team Hippo (HL Stug III) keeps throwing tracks in grass   Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeWed May 04, 2022 5:59 pm
So, the title almost says it all.  I was running tests today on my HL Stug III to see how it performs in grass prior to Aquino this year, and the tank seems to throw a track on just about every second sharper turn.  This is the case with both sides, and in both longer and shorter grass.
The specs on the tank are: upgraded metal gearbox, plastic wheels and suspension, plastic tracks.
Does anybody have experience with this sort of problem?  It would be a shame if Team Hippo had to become strictly an indoor tank.
PostSubject: Re: Team Hippo (HL Stug III) keeps throwing tracks in grass   Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeThu May 05, 2022 7:32 am
Normally this is caused by one of two issues that deal with excessive track length.
1. Stretched track (Usually only occurs with plastic tracks)
2. Idlers/mounts are bending/loose from track tension (Plastic hull)
I assume that it is a HL tank with all plastic running gear? If a metal lower Taigen (Torsion Bar suspension) you could adjust the track tension.
You may have to grab some adjustable track tensioning idlers and install them.
https://www.matomart.com/prodview.php?p=748
PostSubject: Re: Team Hippo (HL Stug III) keeps throwing tracks in grass   Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeThu May 05, 2022 8:08 am
This only happens in grass, though - indoors the tank is fine.  Does this still suggest that the solution is track tensioning idlers (as opposed to upgrading the suspension arms to metal)?
PostSubject: Re: Team Hippo (HL Stug III) keeps throwing tracks in grass   Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeThu May 05, 2022 10:02 am
Yes. As you turn and the track grips the grass, the slack in the track allows grass to try and bunch up at the pivot pins/outer track projections and causes the track horn to ride out of the wheel/idler groove and throw the track.
On a smooth floor indoors, no real grip in turning = no track tension issues.
PostSubject: Re: Team Hippo (HL Stug III) keeps throwing tracks in grass   Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeThu May 05, 2022 10:06 am
In lieu of a track tensioner, would removing a link or two from each track work instead?
(Aiming for simplicity here.)
PostSubject: Re: Team Hippo (HL Stug III) keeps throwing tracks in grass   Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeThu May 05, 2022 2:44 pm
Maybe? Usually a track length is a lot of change to overall length.
If a Heng Long, you may think about taking off the road wheel arms and drilling a new spring index hole to give a stiffer suspension.
Team Hippo (HL Stug III) keeps throwing tracks in grass Hl_spr10
Make sure you drill the correct direction Smile
PostSubject: Re: Team Hippo (HL Stug III) keeps throwing tracks in grass   Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeMon May 09, 2022 4:15 pm
So, it's a good news/bad news situation.  The good news is that track tension adjustment is built right into the tank, so I was able to make adjustments with a screwdriver and test it out.
The bad news is that this is not the only problem causing it to throw a track.  It turns out that one of the suspension arms has too much play, is pulling out of its groove on turns, and taking the rest of the track with it.  I tried to tighten it, but either it requires an allen key I don't seem to have between 7/64 and 3/32, or I'm doing something wrong (and, there's nothing left in the budget to get new tools).  Either way, I think I'm beyond what I can do on my own here.  So, I think I need help.
I've got a set of metal suspension arms pending in my Mato Mart rewards cart, so hopefully that has arrived by the time Aquino rolls around and the arms as a whole can be upgraded.  But, this is getting very frustrating.
PostSubject: Re: Team Hippo (HL Stug III) keeps throwing tracks in grass   Team Hippo (HL Stug III) keeps throwing tracks in grass Icon_minitimeMon May 09, 2022 4:56 pm
Bring the tank with you to Aquino. I'll have a full 1/16 repair motor pool setup there (As per usual with full tools) for fixing everyone's tanks Smile
It is also likely a 3mm hex bit that you need.
» Promise to daughter fully kept after all - Team Hippo has arrived
» Help! HL king tiger tracks needed, tamiya tracks for return
» Cutting The Grass At The Field, Wk Of May 6th
» Thanks To Our Tank Field Grass Cutters
» Grass Cutting & Field Preparation
