SLU  set up  Icon_minitimeby dgsselkirk Yesterday at 8:24 pm
SLU  set up  Icon_minitimeby dgsselkirk Yesterday at 8:20 pm
SLU  set up  Icon_minitimeby dgsselkirk Yesterday at 7:26 pm
SLU  set up  Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
SLU  set up  Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
SLU  set up  Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
SLU  set up  Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
SLU  set up  Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
SLU  set up  Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
SLU  set up  I_vote_lcapSLU  set up  I_voting_barSLU  set up  I_vote_rcap
 SLU set up
buzzy
SLU  set up  Empty
PostSubject: SLU set up    SLU  set up  Icon_minitimeTue Jul 02, 2013 10:16 am
SLU  I have is not coming on can anyone pls give me a bit of guidance ?
It makes a clunky noise when I power it up ?
Does anyone service these units locally if they do fail ?
This is brand new never used ?
thank you guys
SLU  set up  Empty
PostSubject: Re: SLU set up    SLU  set up  Icon_minitimeTue Jul 02, 2013 11:23 am
Sounds like you may be in calibration mode.Check to see if you have a jumper in J1.This is to set your joy stick positions and you will have a visual RED /Green  led flashing on the ESC.
Use the manual to check all your connections. Contact your seller for tech  support as well
SLU  set up  Empty
PostSubject: Re: SLU set up    SLU  set up  Icon_minitimeTue Jul 02, 2013 12:06 pm
Also make sure your receiver is binded properly.
Mine made that sound once, I forgot I switched the the receiver with another one. Embarassed
SLU  set up  Empty
PostSubject: Re: SLU set up    SLU  set up  Icon_minitimeTue Jul 02, 2013 9:23 pm
sometimes mine makes a clunk when i have a switch out of place on my radio a switch or controler that is on
SLU  set up  Soviet10
real_hulu
real_hulu
SLU  set up  Empty
PostSubject: Re: SLU set up    SLU  set up  Icon_minitimeThu Jul 04, 2013 12:18 pm
Clunk may caused by your radio.
Make sure your radio and receiver are working correctly.
SLU  set up  Empty
SLU set up
