Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeby dgsselkirk Yesterday at 8:24 pm
Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeby dgsselkirk Yesterday at 8:20 pm
Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeby dgsselkirk Yesterday at 7:26 pm
Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Henntec Idler System, KT Installation On "Anneliese" I_vote_lcapHenntec Idler System, KT Installation On "Anneliese" I_voting_barHenntec Idler System, KT Installation On "Anneliese" I_vote_rcap
Henntec Idler System, KT Installation On "Anneliese" Empty
PostSubject: Henntec Idler System, KT Installation On "Anneliese"   Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeFri Mar 14, 2014 3:11 pm
In August 2013, I took Anneliese out of service, reluctantly, because she started throwing tracks after a couple seasons running "stretched" the tracks.
Henntec Idler System, KT Installation On "Anneliese" Can_am12
KT's track design preclude the "cheap & dirty" trick you can pull with an HL Panther G; i.e. drop one track link.
I waited through the winter and have realized it is time to act to have this one ready for the April or May meet.
I ordered the Henntec System for it, today;
http://www.etoarmour.com/product_detail.php?productID=HT025
This tank has;
SLU
Upgrade Motors
3:1's
It is a good runner, or was until it started throwing tracks, the plan is to restore it to full mobility.
I plan to do a running report on this, here, from delivery, installation, to finish.
PostSubject: Re: Henntec Idler System, KT Installation On "Anneliese"   Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeSun Mar 16, 2014 12:05 pm
I also order a Henntec System too from ETO and some other items for my KV.
Bob was quick to get back with any questions I had. Though there was an error in shipping they were quick to catch and resolvent it.
PostSubject: Re: Henntec Idler System, KT Installation On "Anneliese"   Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeMon Mar 17, 2014 12:38 am
I hope you'll enjoy installing it and really notice the benefits.
I found it was a good idea to replace the 'tightening' M3 set screw with a larger M3 hex-head bolt. More torque without the risk of stripping the threads out.
of the Pan-Tiger Panzer Div.
PostSubject: Re: Henntec Idler System, KT Installation On "Anneliese"   Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeMon Mar 17, 2014 7:49 pm
HO BOY !!! I will get to slam into Anneliese again (by accident.. lots of ACCIDENT ..) this year !!!
Thanks Glen .... Let me know if there is anything I can do to help !!
Now if I can keep the Sherman from flipping long enough to get a good run at the B!#@&.. tongue
The Great Pan-Tiger pirat
PostSubject: Re: Henntec Idler System, KT Installation On "Anneliese"   Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeMon Mar 31, 2014 8:05 pm
The package just arrived today.
Henntec Idler System, KT Installation On "Anneliese" Img_2015
Henntec Idler System, KT Installation On "Anneliese" Img_2016
Henntec Idler System, KT Installation On "Anneliese" Img_2017
doug818tiger
PostSubject: Re: Henntec Idler System, KT Installation On "Anneliese"   Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeMon Mar 31, 2014 8:15 pm
Looks straight forward. Enough . But I did notice there is not a lot of meat there were the track tensioners are mounted ...when you install it does it sandwich the hull and the tensioner
PostSubject: Re: Henntec Idler System, KT Installation On "Anneliese"   Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeThu Apr 03, 2014 12:44 pm
I got mine for the KV yesterday, the bag wasn't closed properly and when I open the the package all the small bits and parts came tumbling out.
Luckily I had open it low over a flat surface, so I'm pretty sure I have all the parts still.
I do wish the instructions came in English though.
PostSubject: Re: Henntec Idler System, KT Installation On "Anneliese"   Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeThu Apr 03, 2014 7:11 pm
The system is not sandwiched in, I will show how it goes in, in future pictures, rather than try to describe it.
They do provide a reinforcement piece for the installations area, all I can say is that it is a proven system, with good reports on several forums and I am not concerned about it.
1.) Reinforcement panel glued in place.
Henntec Idler System, KT Installation On "Anneliese" Img_2110
2.) Outside of the hull with old idler mount removed to prepare for drilling.
Henntec Idler System, KT Installation On "Anneliese" Img_2111
3.) A bit of a challenge, the HL Tiger II has a screw, rather than an axle like a Taigen Tiger I.  The Henntec system is seet up for an axle.  I found if the threaded portion was cut shorter, the Henntec set screw will hold it in place.
Henntec Idler System, KT Installation On "Anneliese" Img_2112
4.) Replace the itty bitty set screws (little silver thing in the lower right with 3mm cap screws (thanks to Strato for the heads up on this one)
Henntec Idler System, KT Installation On "Anneliese" Img_2113
PostSubject: Re: Henntec Idler System, KT Installation On "Anneliese"   Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeFri Apr 04, 2014 4:51 pm
Looking good Glen, I'm happy you're having a good experience with these.
I did find that I'm often confused as to what parts are made for which, in this case I can't be sure at all which particular idler and axle setup is meant to fit the tensioner... probably the Torro metal lower hull which might already have the solid axles.
Come to think of it, I have no idea which axles are in my Tiger... probably whichever came with the Asiatam hull. They aren't threaded though.
PostSubject: Re: Henntec Idler System, KT Installation On "Anneliese"   Henntec Idler System, KT Installation On "Anneliese" Icon_minitimeSun Apr 27, 2014 8:38 pm
Kinda forgot to take pictures during the final stages of completion.  Embarassed
The tank is back together now, everything seems to work quite well, we will see how it functions, long term, outside.
» HennTec idler system @ ETO armor.
» Anneliese Porsche KT
» SLU Installation in a Panzer IV F2 ????????
» 6W AMP installation to Clark board
» Tamiya LED system
