TeTris MoNk Sergeant
Posts : 238 Join date : 2012-03-22 Age : 30 Location : Sudbury, ON
| Subject: SLU Wiring problems Fri May 18, 2012 12:33 am | |
| Subject: Re: SLU Wiring problems Fri May 18, 2012 1:32 am | |
| I believe with the turret motor it doesn't matter so much. If you attach the wires the wrong way your turret will just rotate the opposite direction. To fix it just switch the plugs on the ESC board. I'm sure Hulu or Tim can confirm this.
Is the other motor an airsoft or recoil? _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: SLU Wiring problems Fri May 18, 2012 1:34 am | |
| Airsoft.... Not that i was gonna use it or anything |
| Subject: Re: SLU Wiring problems Fri May 18, 2012 2:16 am | |
| sorry TeTris just trying to find good batteries to even get the camra to work i covered my exposed wires all with hotglue cause that's what happened to my SLU two wires touched and fried a chip mines a recoil red wire on the top |
real_hulu Sergeant
| Subject: Re: SLU Wiring problems Fri May 18, 2012 9:14 am | |
| Frankly, I don't know... I just try it first before I solder it |
Fireman Tim Corporal
Posts : 193 Join date : 2012-03-22 Age : 51 Location : Stevensville
| Subject: Re: SLU Wiring problems Fri May 18, 2012 2:54 pm | |
| Yes, you can wire the turret traverse and barrel elevation motor either way. If you get the polarity backwards, just reverse the way you plug it into the ESC.
As for the airsoft, the SLU connects to it opposite of the polarity that Heng Long did it.
If you need help getting it finished, I can spare a few minutes tomorrow. |
| Subject: Re: SLU Wiring problems Fri May 18, 2012 4:38 pm | |
| I will bring my solder station to help, if I can.
If any one needs wires for there tanks (red black) I have a lot of cut offs people can have (3 feet long ++) I will try to remember to bring some. _____________________________________________ The Great Pan-Tiger |
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 1:21 pm | |
| I got the 400 motors and Steel Gearboxes finally. Wired everything up and finally.... FINALLY!!! finished installing the SLU... but as Tim can attest for this, the Hobby King controller is messed up six ways sideways with the throttle. |
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 6:52 pm | |
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 7:02 pm | |
| I tested it off ground and realized one of the motors is turning the opposite way when driving foreward... Do I resolver the wires the otherway? |
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 7:07 pm | |
| yep switch the wires on the one going backwards when you are on throttling forwards |
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 7:16 pm | |
| Roger that! Thought Phil had it on right... I just copied where the previous wires were when I got it... But on the brightened this thing is zippy! |
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 7:20 pm | |
| so you got it switched and working now |
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 7:36 pm | |
| Not yet. When I get home I'm gonna switch it. But while I was playing with the controller trying to figure it out it was zipping around side to side like a psycho |
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 9:58 pm | |
| - TeTris MoNk wrote:
- I tested it off ground and realized one of the motors is turning the opposite way when driving foreward... Do I resolver the wires the otherway?
Me and Greg had the same thing happen to us when we hooked up ours to the Panzer III and T-34. We used the same set-up as the HL and we both had to switch the wires around on one of the motors. _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 10:05 pm | |
| Well its running now but i have yet another wire reversed... the turret rotation >.< |
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 10:11 pm | |
| Yea mine was backwards too when I spliced it in with red - red and black - black. Just reverse it at the ESC, done and done _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 10:22 pm | |
| Just unplug it from the ESC and plug it back in the other way around, it will reverse it.
| Subject: Re: SLU Wiring problems Thu Jun 07, 2012 10:56 pm | |
| The amount of times I've unscrewed this tank I swear I should keep the hulls together by magnet..... Thanks guys |
| Subject: Re: SLU Wiring problems Fri Jun 08, 2012 2:52 am | |
| Magnets are a good idea, I have a stack of em that i WAS going to use before I got the miracle asiatam hulls.. lol. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: SLU Wiring problems Fri Jun 08, 2012 3:39 am | |
| that's where i am leary about the magnets and the Electronics
not too sure they go good together
might screw up the electronics so i think i would stay away from them |
| Subject: Re: SLU Wiring problems Fri Jun 08, 2012 4:48 am | |
| - Airbrushler wrote:
- that's where i am leary about the magnets and the Electronics
might screw up the electronics so i think i would stay away from them This crossed my mind as I casually placed my loose speaker atop the ESC... It has since been moved. |
| Subject: Re: SLU Wiring problems Sun Jun 10, 2012 10:03 pm | |
| Subject: Re: SLU Wiring problems Sun Jun 10, 2012 10:32 pm | |
| looks like it's running pretty good now |
| Subject: Re: SLU Wiring problems Sun Jun 10, 2012 10:54 pm | |
| It looks pretty quick!! You'll have to take the bulldog off the side and put on a road runner. beep, beep! _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: SLU Wiring problems | |
