| Subject: Winter Projects? Sun Nov 25, 2012 6:28 pm | |
| I was clean up my work bench and going over my tanks to see if anything need to fixed or improved. Here is the list I came up with. - Sherman - add some storage and weathering / add metal drive sprockets / swap SLUs / add recoil
Panzer 3 - rebuild stowage rack / fix recoil / paint and winter track
Elefant - zimmermit and paint / add SLU
Tiger (Mona) - add recoil and flash / mount emitter and clean up wires
Panther - strip down and rebuild for secret project
Jadgpanther - fix gears / decide what new electronics to use and install
Other Tiger - complete rebuild, possible "what if" project
This is just the list for the tanks. I also have other project in mind too, like a IR bunker, and a CMP truck. What does every else have plan for the winter? _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: Winter Projects? Sun Nov 25, 2012 6:36 pm | |
| Future builds;
1.) Taigen Tiger I Late; Abt. 506, Russia, Spring 1944; my primary build.
2.) Pz IV, Grossdeutschland, Russia, 1942 (conversion of finished airsoft)
3.) HL Jagdpanther, 10th SS, Lake Balaton, Hungary, 1945 (conversion of finished airsof) _____________________________________________ "Luck favours the prepared!."
doug818tiger Sgt-Major
| Subject: Re: Winter Projects? Mon Nov 26, 2012 6:54 pm | |
| Gona build a king tiger for my daughter and try and finish the b17 |
| Subject: Re: Winter Projects? Tue Nov 27, 2012 8:17 pm | |
| UPDATEFuture builds; 1.) Taigen Tiger I Late; Abt. 506, Russia, Spring 1944; my primary build.2.) Pz IV, Grossdeutschland, Russia, 1942 (conversion of finished airsoft) Postponed, waiting for new gearbox release 3.) HL Jagdpanther, 10th SS, Lake Balaton, Hungary, 1945 (conversion of finished airsof) CANCELLEDThe JP My other Tiger I's may get flashes installed. _____________________________________________ "Luck favours the prepared!."
| Subject: Re: Winter Projects? Wed Nov 28, 2012 3:17 am | |
| need to work on the 1-T-34 with SLU have to reroute wiring just to clean it up 2-Panther G get the clark working right still have driving issues 3-Pershing want to add a clark to it and with smoker from Strmnd54 like to add recoil to someday 4-T-34 Stock not sure still debating 5-WSN Tiger ! like to add a clark to that as well 6-KV-1 still debating 7-Wespe i like to finish constructing the top hull wire it up 8-WSN M16 i just got i want to see if clark would make a board for this it would be a nice until cause it's so small still thinking on what way to go fix the guns that are broken or convert to someother type of m16 9-Bruder Truck want to make one fully functional RC i have lots to do thats for sure
real_hulu Sergeant
| Subject: Re: Winter Projects? Wed Nov 28, 2012 4:38 pm | |
| Need work on 1) rework on T-34. strengthen the low hull. rewire the RX-18 on it and weather it. 2) rework on Tiger barrel elevator. change powerful motor. 3) Build my Sherman... 4) Build Leo 2 ?..... 5) Save money for Tamiya JS-2 ???..... |
| Subject: Re: Winter Projects? Thu Nov 29, 2012 4:27 am | |
| Glen, the Jag looks fantastic... will you repaint it??
Various parts for my Indiana tank are arriving, just waiting on the donor PnzIII and extra roadwheels from Mato now... I'll have updates soon! _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Winter Projects? Thu Nov 29, 2012 6:08 am | |
| - Strato50 wrote:
- Glen, the Jag looks fantastic... will you repaint it??!
Thanks; no, it will stay in those colours & markings, It will get some more weathering and some "body work" to lok after things like the removal of the HL external r/c antenna mount an the switches on the bottom of the hull. _____________________________________________ "Luck favours the prepared!."
| Subject: Re: Winter Projects? Fri Nov 30, 2012 6:38 pm | |
| I have cancelled my Jagdpanther conversion. I have run into upgrade gearbox fit problems with it. The whole build hinged around getting a good quality gearbox in it with powerful motors to allow more effective aiming of the tank, in absence of a turret, since they don't fit. that leaves me with no option but to cancel it. A turret-less tank would not fare well in a Sherman-swarm anyway. The Waltersons GB will now go in Panther 103 _____________________________________________ "Luck favours the prepared!."
| Subject: Re: Winter Projects? Sun Dec 02, 2012 4:11 pm | |
| Glen won't the Mato 3:1 version 2.0 work, they have lower profile that the version 1's?
Is there a set for the Stug, that should fit a Jagdpanther. You might have to check the lenght of the drive shaft, but they can be switched. _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: Winter Projects? Sun Dec 02, 2012 4:34 pm | |
| - Stince wrote:
- Glen won't the Mato 3:1 version 2.0 work, they have lower profile that the version 1's?
Is there a set for the Stug, that should fit a Jagdpanther. You might have to check the lenght of the drive shaft, but they can be switched. Yes, the Mato 3:1's would fit the JP but they cannot be fitted with 480's While the Mato's are lower, the stock motors come close to touching each other and the 480's are longer. I thought 480's would be necessary to assist the turret-less JP to be aimed with slight steering inputs, so it seemed to me like, no 480's, no JP. It seemed to me in testing Panthers with Mato 3:1's on short grass that the ability to correct gun aim in small amounts was marginal. Otherwise, I would put the Waltersons in Panther 103 and take 103's Mato 3:1's and put them in the JP. _____________________________________________ "Luck favours the prepared!."
| Subject: Re: Winter Projects? Sun Dec 02, 2012 6:51 pm | |
| UPDATE
Curtis at Immortal Hobbies is sending me some 400's, to see if they fit the Mato's and will fit the JP.
While I was hoping to get 480's in it, the 400's might just get it done. _____________________________________________ "Luck favours the prepared!."
| Subject: Re: Winter Projects? Sun Dec 02, 2012 7:25 pm | |
| Glen the 400's are the same size as the stock motors from the 3:1's. Me and Strato have them in our Sherman's and run fine. Your Jagdpanther should be able to turn better than the Sherman's because of the wider track. _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: Winter Projects? Sun Dec 02, 2012 7:41 pm | |
| - Stince wrote:
- Glen the 400's are the same size as the stock motors from the 3:1's. Me and Strato have them in our Sherman's and run fine. Your Jagdpanther should be able to turn better than the Sherman's because of the wider track.
Do you think there will be a noticeable power increase with the 400's over the 3:1's with the stock Mato motors? I am thinking from the viewpoint of being able to pivot in place a few degrees for aiming the gun. _____________________________________________ "Luck favours the prepared!."
| Subject: Re: Winter Projects? Tue Dec 04, 2012 7:16 pm | |
| Well, even the Mato 3:1's won't fit the JP, the left motor is too high.
Consequently, that finishes the idea of a JP project. _____________________________________________ "Luck favours the prepared!."
| Subject: Re: Winter Projects? Tue Dec 04, 2012 10:17 pm | |
| If shaved the plastic down from the top hull would that help? _____________________________________________ HL Panzer III | HL Tiger | HL Jagdpanther | HL Panther | Mato Sherman Hooben Elefant | HL Pershing | HL Bergepanzer IV | Tamiya Leopard 1A | WSN T-34 HL "Golden" Pan-Tiger | M16 Halftrack | HL Panzer IV | Tamiya KV-1 | Tamiya Tiger
| Subject: Re: Winter Projects? Tue Dec 04, 2012 10:22 pm | |
| - Stince wrote:
- If shaved the plastic down from the top hull would that help?
No, I'd have to shave right through the hull, it needs an extra 1/8" clearance. _____________________________________________ "Luck favours the prepared!."
| Subject: Re: Winter Projects? | |
