Howdy! I thought winter was about over. Then I look out the window and can't see the 100m to the road. Ha haa. I had tried earlier to take one of my Blizzards out in the field and its esc is toast.
So it was finally a day to wrench on some tracks. I decided to give my Tiger 1 some long overdue attention. I had previously taken it apart for a stationary turret to be used at Aquino. While the turret is out, I am going to add barrel recoil. Something it never had before. I am using one of Jarlath's Custom Creations recoil kit. An awesome kit if you've never seen one. The problem I have run into is I can not get the barrel out of the mantlet. I'm not sure if it is glued in there. Has anyone else had this problem before? Any suggestions?
Heng Long Tiger 1 with custom paint. Not done by me. I've tried scoring around the barrel with an exacto knife.
It has an aluminum barrel that goes all the way to the brake. Yes, there are two led's in the mantlet. One is the IR, the other flashes with the MG. That one is coming out.
Not tanks. What you all think of the Unimog I've been working on?
Hope everyone is doin well. Hopeing Cindy and I will be able to get up to see you all soon. BTW Jarlath, I'm going to need another kit when I finally get to that PZ3.
Cheers!
