Al.M Retired
Posts : 75 Join date : 2015-09-14 Age : 67 Location : Cambridge
| Subject: Plugs for Clark Board Sun Jan 03, 2016 5:21 pm | |
| Hey guys. I am looking for the little tiny plugs that fit the two prong plug for the gun flash and one other plug. I will need 4 of them form the two tanks. Any idea where i can get them? This would be for pin locations J1 and J3 _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
| Subject: Re: Plugs for Clark Board Sun Jan 03, 2016 6:20 pm | |
| I think you can order them from Clark when you order the boards. Should have couple to spare, but not 4.......... |
Al.M Retired
| Subject: Re: Plugs for Clark Board Sun Jan 03, 2016 6:33 pm | |
| Didn't know that I had to order them when I ordered the boards. Was under the impression that all needed plugs came with. I will buy what ever you have spare. _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
| Subject: Re: Plugs for Clark Board Sun Jan 03, 2016 7:18 pm | |
| Al, I will see what I have in the spare bin......... Also, if you upgrade to high intensity flash unit then you don't need to use the little connector for the flash. The only one you really need is for the IR. |
hachleopard2 Captain
| Subject: Re: Plugs for Clark Board Sun Jan 03, 2016 8:20 pm | |
Al.M Retired
| Subject: Re: Plugs for Clark Board Sun Jan 03, 2016 8:25 pm | |
| Thanks Mike greatly appreciated Going to try LED and compare to the T64 that i have with High intensity and see what looks more life like. _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
Al.M Retired
| Subject: Re: Plugs for Clark Board Sun Jan 03, 2016 8:31 pm | |
| Have you ordered from them and if so, how long to get here from there? _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
| Subject: Re: Plugs for Clark Board Sun Jan 03, 2016 9:08 pm | |
| Seller will tell you when it arrive. My guy has order before but use up all for new tanks |
| Subject: Re: Plugs for Clark Board Wed Jan 06, 2016 8:42 am | |
| The high intensity flash is a great deal, they're like $11 or something and really SNAP, it'll light up a dark room with gun flash.
I have a mix of LED's and the high-capacity and really, either is fine.
Those tiny JST plugs are a pain, I really could never figure out who uses what standard plug and I wish ordering them in bulk was easier. Clark did, or used to.. supply a couple of those cables with each board, IR and Muzzle Flash, I have a couple laying around for future projects :\ _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Plugs for Clark Board Wed Jan 06, 2016 8:56 am | |
| Clark actually never supplied them Curtis use to add them in as his value added re-seller. |
| Subject: Re: Plugs for Clark Board Wed Jan 06, 2016 9:03 am | |
| I took care of Al from my stash. I order them in batches e-bay... Can never have too many plugs and wires... :-) _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: Plugs for Clark Board Wed Jan 06, 2016 10:18 am | |
| - dgsselkirk wrote:
- I took care of Al from my stash. I order them in batches e-bay... Can never have too many plugs and wires... :-)
Especially when we accidentally let the magic smoke out. _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Plugs for Clark Board Wed Jan 06, 2016 10:20 am | |
| Yes, we all love the magic smoke.... I will be fusing every one of my tanks from now on... _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
Al.M Retired
| Subject: Re: Plugs for Clark Board Wed Jan 06, 2016 12:05 pm | |
| what size fuse will you be using? _____________________________________________ King Tiger, Sherman. All under construction. Now also T34/85 |
| Subject: Re: Plugs for Clark Board Wed Jan 06, 2016 12:09 pm | |
| I am going to try 5A first but I have the feeling that will blow under load so it will probably be a 10A Michael has been playing with them and I'm sure will throw his 2 cents in too... _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: Plugs for Clark Board Wed Jan 06, 2016 12:59 pm | |
| I have blown 3A under normal test runs, but if you are doing work on the electronics I would use 3A just to be more sensitive and conservative.
I think 5A is good for everyday use but if the tank is running fine and you have a heavy load then go with 10A. |
| Subject: Re: Plugs for Clark Board | |
