Tiger Power Second Lieutenant
| Subject: had these days? Mon Jan 11, 2016 2:39 pm | |
| So i ordered my KT and guess what shows up right before i have to leave for work, dident even get to smell the box. Now i am at work itching to get home and open it
gaaa work fire wall stoping from hosting photo _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: had these days? Mon Jan 11, 2016 6:48 pm | |
| getting closer to open my KT 4 hours to go _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: had these days? Mon Jan 11, 2016 7:18 pm | |
| Just like Christmas...Feel great every time I order parts .Can't wait to get to the post office |
| Subject: Re: had these days? Tue Jan 12, 2016 12:18 am | |
| k so got my tiger opened everything works but the barrel up and down. The gear is spinning but no movment any ideas? _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: had these days? Tue Jan 12, 2016 12:27 am | |
| Kyle, is the barrel loose or stuck in the position? The spring inside could have gotten loose and is not providing counter force for the elevation motor to work. |
| Subject: Re: had these days? Tue Jan 12, 2016 12:33 am | |
| well after ripping it apart I see the problem there is a little "finger' that rides the gear is broken off _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: had these days? Tue Jan 12, 2016 1:16 pm | |
| the broken part but got it all fixed last night 3am all done _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: had these days? Tue Jan 12, 2016 2:12 pm | |
| WOW! Rare that piece breaks... _____________________________________________ "There are things in Russia which are not as they seem..." Georgy Konstantinovich Zhukov
| Subject: Re: had these days? Tue Jan 12, 2016 3:33 pm | |
| worst part is it came out of the box like that, o well atlest i got to rip it all apart and see how she work lol. _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: had these days? Sun Jan 17, 2016 9:32 pm | |
| ok mike so I tried the board, it let the barrel recoil and sound no flash, an dean I don't think this spin is normal it just went around 5 times in a row without me even touching it, either it has some trapped ww2 guy spirit or thing is junk, maybe could put it to the purchase of your ztz as I know you goanna give me a deal anyways lol _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: had these days? Sun Jan 17, 2016 9:51 pm | |
| Kyle, did you put the 2 pin plug back in to the board as well ? That is what triggers the flash. |
| Subject: Re: had these days? Sun Jan 17, 2016 9:55 pm | |
| yes it the stock spot, If I remove board it works, I tried moving the little pin over the light just stays on. it might just be this POS tiger _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: had these days? Sun Jan 17, 2016 9:57 pm | |
| Okay let me check the manuals again and get back to you on this...... |
| Subject: Re: had these days? Mon Jan 18, 2016 1:32 pm | |
| Kyle, if you trace the flash from the barrel, where does it go ? Does it go into the 8 pin board and then come out to the 5 pin + 2 Pin ? Or is is separate from everything else ? If it goes into the 8 pin, can you trace it back to the 2 pin plug ?
I am just not sure if the 2 pin plug is actually the flash and it is not clear on the picture where its going. |
| Subject: Re: had these days? Mon Jan 18, 2016 1:42 pm | |
| Hey at work can check when home but when I took the two pin out everything worked but the flash, the board goes from 8 to 4 pin I think is it possible it's not powering the board up. Cus with the board on and the 2 pin in the right spot it has no flash so it's like it uses power from the original connector _____________________________________________ Tiger PowerDer Tiger ist auf dem losen |
| Subject: Re: had these days? | |
