| Dual Apple base - TBU & HBU capable | |
| Subject: Dual Apple base - TBU & HBU capable Thu May 11, 2017 1:34 pm | |
| So I know that Clark has their Tamiya/Impact apple mount and cable set. I'm looking to make one that will be somewhat universal... I picked up a 40x3 pin array. I plan on trying to see if I can create a universal one for both the Tamiya/Impact Apple mount as well as the HL/Taigen Apple mount. Going to look at doing this... Which I plan to modify my 3D-printed version of this. (Tamiya TBU Base with lock section). Any interest? |
| Subject: Re: Dual Apple base - TBU & HBU capable Thu May 11, 2017 1:37 pm | |
| Whoops I have 6 & 7 Mixed up in my sketch... But it will depend on the rigidity of which side is small vs large pin on the HL Apple.
| Subject: Re: Dual Apple base - TBU & HBU capable Thu May 11, 2017 1:43 pm | |
| Ingenious but why would you need Heng Long if you have Tamiya already ? |
| Subject: Re: Dual Apple base - TBU & HBU capable Thu May 11, 2017 1:53 pm | |
| To market for a universal base Some may not have Tamiya's yet... Or may only have one and want multiple tanks to run... |
| Subject: Re: Dual Apple base - TBU & HBU capable Thu May 11, 2017 1:55 pm | |
| Subject: Re: Dual Apple base - TBU & HBU capable Thu May 11, 2017 2:03 pm | |
| IBU use a different connector than Clark? Or same JST-XH 5 pin? |
| Subject: Re: Dual Apple base - TBU & HBU capable Thu May 11, 2017 3:02 pm | |
| IBU has both, Standard Heng Long JST 5 pin and also Tamiya base connector. |
| Subject: Re: Dual Apple base - TBU & HBU capable Thu May 11, 2017 3:19 pm | |
| The HL/Taigen/Clark MFU boards are all JST-XH 5 pin with the same pin out. So IBU has the same pin out with both a JST-XH (2.5mm pitch) 5 pin and a Tamiya Molex Micro-Latch (2.0mm pitch) 5 pin connector? |
| Subject: Re: Dual Apple base - TBU & HBU capable Thu May 11, 2017 3:24 pm | |
| Yes. Its plug and play compatible with Heng Long IR tanks, even more so then Clark because the 8 pin plug is also plug compatible. |
| Subject: Re: Dual Apple base - TBU & HBU capable Fri May 12, 2017 10:55 am | |
| Oh that's ambitious, and practical. I like it _____________________________________________ Tiger I - Panzer II - Panzer III - Panzer IV - Chi Nu Kai - Panther G - KV-1b 756(r) M4A3(76) Sherman - T-34/85 - M3 Grant - SECRET PROJECT
| Subject: Re: Dual Apple base - TBU & HBU capable Fri May 12, 2017 11:18 am | |
| Gonna make a couple bases up maybe this weekend.. At least get the components/wiring done for it... Plan on using ABS in the 3D printer for strength. Will be my first 3D print job... IF I can get it to work |
| Subject: Re: Dual Apple base - TBU & HBU capable | |
