Dual Apple base - TBU & HBU capable Icon_minitimeby dgsselkirk Yesterday at 10:07 pm
Dual Apple base - TBU & HBU capable Icon_minitimeby Abteilung 506 Yesterday at 7:46 pm
Dual Apple base - TBU & HBU capable Icon_minitimeby dgsselkirk Thu Apr 25, 2024 7:26 pm
Dual Apple base - TBU & HBU capable Icon_minitimeby dgsselkirk Tue Apr 23, 2024 3:37 pm
Dual Apple base - TBU & HBU capable Icon_minitimeby Hammertime999999999 Sat Apr 20, 2024 6:40 pm
Dual Apple base - TBU & HBU capable Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 5:56 pm
Dual Apple base - TBU & HBU capable Icon_minitimeby Chimo Fri Apr 19, 2024 4:40 pm
Dual Apple base - TBU & HBU capable Icon_minitimeby Hammertime999999999 Fri Apr 19, 2024 3:22 pm
Dual Apple base - TBU & HBU capable Icon_minitimeby dgsselkirk Thu Apr 18, 2024 6:31 pm
Dual Apple base - TBU & HBU capable I_vote_lcapDual Apple base - TBU & HBU capable I_voting_barDual Apple base - TBU & HBU capable I_vote_rcap
Dual Apple base - TBU & HBU capable Empty
PostSubject: Dual Apple base - TBU & HBU capable   Dual Apple base - TBU & HBU capable Icon_minitimeThu May 11, 2017 1:34 pm
So I know that Clark has their Tamiya/Impact apple mount and cable set. I'm looking to make one that will be somewhat universal...
Dual Apple base - TBU & HBU capable Array10
I picked up a 40x3 pin array. I plan on trying to see if I can create a universal one for both the Tamiya/Impact Apple mount as well as the HL/Taigen Apple mount.
Going to look at doing this...
Dual Apple base - TBU & HBU capable Hbu-tb10
Which I plan to modify my 3D-printed version of this. (Tamiya TBU Base with lock section).
Dual Apple base - TBU & HBU capable 3d-pri10
Any interest?
PostSubject: Re: Dual Apple base - TBU & HBU capable   Dual Apple base - TBU & HBU capable Icon_minitimeThu May 11, 2017 1:37 pm
Whoops I have 6 & 7 Mixed up in my sketch... But it will depend on the rigidity of which side is small vs large pin on the HL Apple.
PostSubject: Re: Dual Apple base - TBU & HBU capable   Dual Apple base - TBU & HBU capable Icon_minitimeThu May 11, 2017 1:43 pm
Ingenious but why would you need Heng Long if you have Tamiya already ?
PostSubject: Re: Dual Apple base - TBU & HBU capable   Dual Apple base - TBU & HBU capable Icon_minitimeThu May 11, 2017 1:53 pm
To market for a universal base Smile Some may not have Tamiya's yet... Or may only have one and want multiple tanks to run...
PostSubject: Re: Dual Apple base - TBU & HBU capable   Dual Apple base - TBU & HBU capable Icon_minitimeThu May 11, 2017 1:55 pm
I see. Cool.
PostSubject: Re: Dual Apple base - TBU & HBU capable   Dual Apple base - TBU & HBU capable Icon_minitimeThu May 11, 2017 2:03 pm
IBU use a different connector than Clark? Or same JST-XH 5 pin?
PostSubject: Re: Dual Apple base - TBU & HBU capable   Dual Apple base - TBU & HBU capable Icon_minitimeThu May 11, 2017 3:02 pm
IBU has both, Standard Heng Long JST 5 pin and also Tamiya base connector.
PostSubject: Re: Dual Apple base - TBU & HBU capable   Dual Apple base - TBU & HBU capable Icon_minitimeThu May 11, 2017 3:19 pm
The HL/Taigen/Clark MFU boards are all JST-XH 5 pin with the same pin out.
So IBU has the same pin out with both a JST-XH (2.5mm pitch) 5 pin and a Tamiya Molex Micro-Latch (2.0mm pitch) 5 pin connector?
PostSubject: Re: Dual Apple base - TBU & HBU capable   Dual Apple base - TBU & HBU capable Icon_minitimeThu May 11, 2017 3:24 pm
Yes. Its plug and play compatible with Heng Long IR tanks, even more so then Clark because the 8 pin plug is also plug compatible.
PostSubject: Re: Dual Apple base - TBU & HBU capable   Dual Apple base - TBU & HBU capable Icon_minitimeFri May 12, 2017 10:55 am
Oh that's ambitious, and practical. I like it Very Happy
PostSubject: Re: Dual Apple base - TBU & HBU capable   Dual Apple base - TBU & HBU capable Icon_minitimeFri May 12, 2017 11:18 am
Gonna make a couple bases up maybe this weekend.. At least get the components/wiring done for it...
Plan on using ABS in the 3D printer for strength.
Will be my first 3D print job... IF I can get it to work Smile
» SOLD board , radio , receiver , apple , base and blue ring
» Tamiya Apple and HL Apple
» RC Battle Apple
» Tamiya IR Receiver (Apple) Component Questions
» Looking for TBU base
Can-Am RC Tank Club :: The Motor Pool (Builder's Section) :: Miscellaneous Builds-
