Update: Disregard - Fixed.
Hi folks,
Accidentally dropped a screw inside one of the gearboxes on my M36.
Took the gearbox cover off, removed the offending screw, reattached the cover, reinstalled the gearbox without incident, and reassembled the tank.
All's well - or so I thought.
However now my tank will not run straight, but wobbles or veers to the left. The RH track seems to run at normal speed, LH is much slower. With the tank up on blocks, when starting & stopping the RH track seems to spin more freely and keeps coasting for a bit when I turn off the throttle. The LH track stops right away.
Same thing with the tracks removed. The LH side motor runs much slower so it's not a problem with the tracks binding on anything.
Can't see anything obviously wrong with the gearbox.
Looking for any help/advice. Again, its a Mato M36 (same lower as a Sherman/M10)
